Re: merc 80hp - similar to wrenchtrnr72
17" sounds about right for that boat size. (If I was 'propping' that's the size I'd start with anyway). If the prop is the wrong size, too big, then it will overload the engine and it wouldn't run up to the right rpm. If the prop is too small it 'light loads' the engine and it'll over rev.<br /><br />Was the mechanic a marine mechanic? Did he reset the carb float levels? If so, why, were they too high or too low? and how much? and were both done?<br /><br />Other than that, if you have a bit of engine knowledge, start with the basics. Check the compressions, then with the engine running on the flushes, pull each plug lead off in turn, using insulated pliers. The engine should loss about the same revs with each cylinder missing. If that all seems ok, then check the carbs are opening fully and they are both opening at exactly the same time (engine NOT running). If you have a timing light, take it all down the lake and check the maximum advance. NEVER do this on the flushers. An engine should not be run at more than idle on the flushers.<br /><br />Chris.............
