Merc 800/850 Starter Problem - Any tips or Repair Guide?
davidnash
I have a starter on a 4 cylinder 80hp Merc which is failing to crank the flywheel with anywhere near enough kick/force (probably a full turn takes around 2-3secs).
The symptoms are like either there is not enough power, or the bushes or something else are gone in the starter, or there is too much physical resistance somewhere in the starter.
If the starter did turn properly then the engine might start (but I don't know as we've only bought it a few months ago yet to have it running).
We installed all the wiring ourselves, so that doesn't seem too likely to be the culprit although I will clean and re-do every connection today.
Can anyone give me some tips about what in the starter could be causing this, or even better have a link to or pdf copy of some manual that can lead me through a troubleshooting process for the starter.
Ideally a guide/manual would be for the correct or a similar starter but I am a bit desperate. A) this would mean it has the correct tolerances etc the parts in my starter can wear to; and B) I found a guide for a car starter but it is very very different with inbuilt solenoid, very complex pinion method for deploying bendix etc etc and thus of limited use.
- What should I grease when I dissemble/reassemble the starter?
- What can I cheaply replace (which the problem could be) other than bushes?
- Do I need special mercury replacement bushes, or will random generic bushes be sufficient? Or are there just certain tech specs to match up on purchase?
- Could the big magnetic cylinder in the starter have lost its magnetism and what can I do about it?
- I bought a new Solenoid, could it be that, or can we rule it out as at least the starter turns VERY slowly?
The odd thing is when we bought the engine a few months ago, the seller put a battery directly to starter to try and start the engine. The engine turned over WELL then (though motor did not actuallly start because ignition etc was not wired up).
The only thing that has changed since then is the addition of a solenoid (previously missing) and wiring in the ignition circuit with key switch etc etc. So hardly anything has changed accept for the addition of these circuits but now the starter will not spin at the correct speed/force.
So to see if starter worked at speed at all, we took the starter off the engine and applied the battery directly to it (so this is similar to the demonstration when we purchased the engine, but starter is out not in) - the starter does spin fast, but my friend tells me it is without enough kick/force to turn the flywheel. (ie so once the friction of flywheel is added the thing barely turns at all). So if my friend is correct, somehow the starter has completely lost most of its kick/force even though essentially all we did was wire in all of the circuit previously missing (large %) and add a solenoid.
The only other thing we changed is migrating from seller's old bangedup jump-pack (ie battery in plastic case with leads to jump car with) to our new same-physical-size jump-pack - could his have had many more amp-hours or something? Maybe? And could a car battery produce so significantly more power the starter might actually fire properly when it doesn't with a jumppack?
The engine is probably a Mercury 800 (even though it has 850 cowling) with serial 8475339, which would fit in the 8067015 and UP category for Mercury 800s.
This is my first engine and although a decent backyard mechanic with cars, this is getting me and my aviation engineer mate very confused, so all help is very gladly appreciated!
Thanks,
David
Re: Merc 800/850 Starter Problem - Any tips or Repair Guide?
David, A lot of times slow starters is caused by corroded battery cables. They can corrode in the middle of the cable, where it is hard to find. If the starter spins faster with jumper cables directly to the battery, it is likely your cables are bad.
That starter may be dirty or the brushes may be bad. You may disassemble and clean up the commentator with some sandpaper. Clean the brushes with some mild solvent (not acetone). Grease the bushings a bit. There is likeley a overload switch inside the starter. You might clean the contacts, if they need it.
Moody Blue
Try taking the spark plugs out and operating the starter. Any difference? Can you turn the motor over by hand ? (Ignition off and plug wires pulled off plugs). Is it really hard or relatively easy?
I had a starter on one of my motors that acted the same way. WHen I took it apart it was full of rust and corrosion. Basically scrap. No idea how it got that way (submerged, condensation?) but it was bad. Hopefully you are not in the same situation.
Measure the voltage at the starter terminal when operating the starter. Post the results.
Maybe I missed it but are you sure you have a good battery. Don't go after a starter until you've proven its the culprit. As for rebuild tolerances, all there is to rebuild are the brushes and the bushings at each end. Clean up the commutator and go. Unless the starter is totally trashed (as in full of rust and debris or the windings have come apart or shorted) it can be repaired. Parts are available at any auto starter/alternator rebuilder in town.
davidnash
All,
Thank you very much for your replies. I took the starter to an electrical engineering firm who essentially cleaned it for ?35, fairly reasonable I thought. Apparently this was much needed, prior to cleaning the engineer said he could stop it with his hand! (even though when we took it apart it looked quite clean...)
I've also replaced all the thick cables leading to the solenoid etc.
@Moody: I haven't yet tried to turn the engine since your post, but IIRC I believe we already tried this and it was not possible. Do you then go on to say your starter was corroded, or do you mean your entire engine? Sinking feeling that you could mean it's likely the engine is very corroded (seems possible even though it was winterised etc etc).
Anyway I'll be trying again tonight and will let you all know the results! We'll have a car battery on hand as well if the jump pack doesn't work - my theory is that a jump pack has too small a battery in it to provide enough CCAs to start a big outboard.
It's probably been a combination of all 3 things!
