merc 60 1989 over heating problems
fishmonger.33
i have a merc ury 60 hp and am having som overheating problems. the water pump in perfect and the impeller brand new. the carb is set right. im wondering if there is build up in the chambers. thanks.
MCM
Re: merc 60 1989 over heating problems
Hi, sounds like a thermostat problem, once you get it out put in a pot of boiling water and see if it actuates if it doesn't replace it. Hope this helps.<br /><br />Mike :)
fishmonger.33
thanks mike, but there is no thermostat on my motor if you have any other ideas i am willing to try anything. thanks. fishmonger.33
fishmonger.33
could the cause of the problem be that the motor doesnt have a thermostat and it is supose to?
MCM
I don't know, it's probably either stuck or rusted shut. I had the same problem on my 50 Johnson, I replaced the impeller and it still kept overheating,<br />I didn't know it had one at the time either. If its supposed to have one and its been removed it probably wouldn't overheat because the water would be circulating continuosly. Hope that helps.<br /><br />Mike :)
fishmonger.33
the water pump is working @ full capacity full psi and the stream is perfect. there is thermostat and the water is circulating fully . thanks. fishmonger.33
MCM
Glad I could help.<br /><br />Mike :)
fishmonger.33
it is still overheating a bit though and is this because there is carbon deposits in the cambers? fishmonger.33
MCM
What makes you say its overheating a bit, is the horn going off or have you got a temp gauge. Is it a 2 or 4 stroke, if its a 2 stroke and the oil/gas mix was to lean it might cause it to run hot, running it at an idle can also increase the temp, the impeller pumps more water at higher rpm's. I think carbon deposits would probably just make it run rough. Hope that helps a little.<br /><br />Mike :)
fishmonger.33
the water pump is a presurized system and is is always pumping ample water. the oil/gas mix is ok we usualy dont run at idle to much but the alarm goes off is the motor is running at full out, amd it doesnt matter how much you lower the pitch on the prop we tryed 15, 14, 13 and it wuold still overheat<br />it is a 2 stoke and it has the auto oil injection and you put staight gas in the tank. thanks. fishmonger.33
MCM
Hi, fishmonger, I can't think of anything else that would cause it to overheat, you might post this on the Merc site not thatthere should be that much difference, a motor's a motor right.<br /><br />Mike :)
fishmonger.33
thanks mike you helped me eliminate a few possibilities. thanks. fishmonger.33
