Merc 50hp charging system
Dizyanna
Hi all<br />I have a 50hp Merc Blue Band ser#3482234. I looked it up on John's Old Merc site and it stated that it came in non charging and charging circuit. Since it is elec start, I assume their is an alternator/generator. How do I determine?<br />16' Safetmate/50hp Merc 1976 22' Grady White
inlineal
Re: Merc 50hp charging system
A lot of the old Mercs from that era had point type distributers which were a basic magneto which does not need voltage to operate. The battery was for starting only..
Nos4r2
Easiest way to determine if your motor has a charging system is to put a voltmeter across your battery and see if the voltage increases while the engine is running.
crem1
Hi!<br /> Sounds like you have a similar engine to mine. There should be a rectifier on the port side attached to the front supporting frame near the top. Looks like four layers of rectangular sliced cheese.<br /><br /><br />crem1
Dizyanna
Thanks fellas, I'll check into the suggestions and keep you posted. reason I need to know is I want to hook up a tach
Dunaruna
Check your control lever box for the tach connection (a 3 pin plug), just under the key. Is it there, are wires connected to it?
