rolmops
Thread starter- Joined
- Feb 24, 2002
- 5,755
After completely rebuilding this 1967 engine to the point where all that was left to do was reattach the lower unit.While doing that, I got in deep trouble.Being used to Johnnyrudes I just was not really careful with the shifting part and of course the rod and shaft parts did not slide smoothly together.Now it seems to me that the female part coming down from the housing is too short and after 20 tries working on it almost till dawn it dawned on me that I need some good advice.<br />Is there a way to "stretch" the shift rod coming from the housing?<br />Can I take a hammer and dowel and tap the female opening a bit wider? or is that a no no?<br />How can I direct the female part so the male part will slide in?<br />In what position do I turn the lower unit so that after having made the right connection it will work,I do have it in forward, but there is a 200 degree turn on the shaft and I need to know whether to turn it all the way clockwise,counterclockwise or somewhere in between?<br />I know this post sounds a bit Freudian ,but it is not meant to be so.
