merc850
- Jul 7, 2010
- 2,046
Re: Merc 500 Revival
You should have the fuel system working when you test the compression, for oiling reasons, so I would install the end cap then spin it over to test. You can test it later when it's warmed up for an absolute reading.
Follow these steps to reinstall cap: The seals should have Loctite on their metal frames when installed and grease on their lips, put Perfect Seal or Permatex on the Oring area and some oil to help slide the bearing cap into place.
Push the cap back in (make sure that the bolt holes are lined up) and you can lightly tap it in for final seating.
Replace the cap bolts and tighten the crankcase bolts. Make sure to reinstall any shims that have been installed.
