Bt Doctur
- Aug 29, 2004
- 19,557
Re: Merc 5.7L thunderbolt pulled to fix transom. Now what?
Posting this tool I made to help show in what direction the motor must be moved after the motor is reinstalled.
Using a input shaft, you remove the yoke area and drill and tap for a removal bolt ,no particular length
Next you remove .125 of material from the shaft. .125 or 1/8 inch. this shaft is now 1/8 inch undersized in relation to the gimbal bearing.
a 1/8 inch welding rod can be used as a rough gauge to center the shaft in the gimbal bearing by shifting the engine, followed by the actual alignment bar.
