Merc 470 help
brezmer
trying to find the best place to locate parts for my Merc 470 4cyl. if anyone has some leads, please feel free to chime in. im looking for the water pump houseing gasket, the water pump impeller gaskey(normally sold as kit) and gaskets and steel plugs for heat exhanger..... thanks in advance...
Faztbullet
Re: Merc 470 help
If you need gaskets for the front of engine water pump you can order here at iBoats. The part # for water pump on engine front is 18-4380 and the impeller kit if for lower unit is part # 18-3217. You can get the plugs or exchanger repaired at a radiator repair shop.
