Merc 454 - Marine vs Auto water pump
dcg9381
Do I need to buy a marine specific water pump for my 7.4L Mag motor?
Any recommendations on where to order? Need a water pump, impeller, and probably replace a few lower hoses and 2 o-rings on the out drive...
Haut Medoc
Re: Merc 454 - Marine vs Auto water pump
Yes, you should get a marine specific water pump.....:)​
HT32BSX115
If you have closed cooling (and you're using 50:50 antifreeze) could probably get away with an automotive waterpump.
180shabah
Get the marine pump, it'll have a bronze impeller(which won't matter if you are FWC) and a stainless backplate that won't rot out every few years.
HT32BSX115
You can buy a water pump for that engine from any number of places.
The first one being right here on iboats.
Or go here for the water pump, impeller and other stuff.
You can also get the correct one at NAPA.
Ebasicpower might be a little cheaper but don't forget to consider the shipping etc.
Cheers,
Rick
Scaaty
And a Ceramic bearing/bushing....
HT32BSX115
I would still get a marine pump in any case! I guess I should have said that up front!!;)
dcg9381
Yes, I'm freshwater cooling... Thanks for the references. It's got a slight leak somewhere (probably the weep hole) - indicating impending doom.. :)
