merc 400 EL 45hp 1960 trying to adjust speed control linkage.<br />ok I have Old Outboard Motor rapir manuel from the library.<br />it says to "with engine not running move the speed control lever toward the "FAST" position until magneto advance stop just touches the crankcase. refer to fig M7-6. Loosen the screws securing the throttle actuator assembly to economizer collar, then move the actuator plate until 0.015 clerance exists between follower and throttle cluster lever. tighten the attaching screws. Move the speed control lever to "FAST position and adjust the full throttle stop screw to allow 1/64 inch travel to full open position. <br />then it gose on about slow idle adjustment.<br /><br />my problem is I dont see or understand the frist part about "slowly move the speed control lever toward "FAST" position until magneto advance stop just touches the crankcase". Nothing on the mag. actually touches the crankcase in any position that I can see..and I cant see from the only figure M7-6 what they are talking about, it only refrences 1, cluster lever 2,pick up pin 3, adjusting cap screw 4, full throttle stop screw A. adjustment clerance.<br />where is the magneto advance stop? and where dose it touch the crankcase. nothing on the mag touches the crankcase at all.it is the right section for my motor figure is the same and all just not enough info. I see the attaching screws and the actuator everything in the figure M7-6<br />just not where it starts to touch crankcase?<br />baffled Ben.
