Re: Merc 40 problems
Watch the timing advance linkage, while someone operates the throttle from idle to WOT,and back a few times (engine not running). Look for any play.<br />If you find play,see if you can eliminate it by tightening loose bolts or whatever.<br />Once you are happy with that, pull the plugs and look for one that looks brand new (clean), or much cleaner than the other.<br />This would indicate water jacket leaking into the cylinder via head gasket or exaust port plate.<br />Also, check the small hose on top of the carb,going to the block by the reed box.<br />It can drive you buggy,and it is hard to get to (requires removal of the carb).<br />But even a pinhole leak in that hose, and it'll miss and surge and sputter and...<br />Good luck , and letme know what you find.
