Re: Merc 4.5 lacks power
If it acts like it's running normally, proper RPM and all, but doesn't seem to push the boat as it should, check that the hub has not "spun-out".<br />It will act like a car lossing traction on a slick road.<br /><br />Other than that, try switching gas tanks.Look for loose connections on the fuel line ,or other small cracks/holes in the fuel line. Check that the carb mo8unting bolts are tight. Also, if you didn't use a new gasket when R/R the carb, remove the carb and install a new gasket. You can make one from gasket material available at auto parts stores for a whole bunch cheaper.<br />But trust me, this is a common oversight,as the original gasket "looks fine". But they will rarely seat the carb properly a second time.
