Chrisravosa36
Thread starter- Joined
- Aug 16, 2015
- 622
Ok y'all, I'm running a 73' Carefree 13.5ft fiberglass boat. Has an 86, Merc 25. It's running on a short shaft transom. I'm currently running a 12p prop, unsure about diameter. I have the trim on the highest hole, gps gets 25mph on this hole at wot, all the other holes get 23 and about 24. I notice one way turning is easy and one is harder. I was told this could be the trim Anoed. It leans twos the left side. I'm also looking into a new stainless prop, there are a few diffrent diameters and I was wondering what I should go with, I'l get my wot rpm and current diameter tomm. How much speed do you usually gain with a stainless? Also how do I adjust that Anoed? Thanks
