Does the engine turn over? Or is completely dead? If later I know this may sound silly, but check your MOB kill switch.
need a gauge / I guess NAPAthis is efi??
yeah, the water separator should be plumb full when operating
do you hear the fuel pump run for a few seconds if you turn the key to the run position?? (not cranking)
have you checked for blockage in the tank?? (fuel pickup)
have you checked the fuel vent line?? will try...
pressure/vaccuum test the fuel pump??
