Browntailer
Thread starter- Joined
- Apr 3, 2011
- 4
Need to replace the water shutter in my 2005 Merc 3.0, s/n 0w303873 (found half of it when I cracked the lower half of the drive to change the impeller). 2 dealers told me that the engine actually runs warmer than normal without it. Anyway, does anyone know how / have an easy way to get the rubber boots/ sleeves off the the pipe assembly? The parts catalog calls them simply "exhaust tubes" and the P/N is 32-9094t. They are so thick and heavy/rigid that I can't even budge them even though I got the clamps off (can't roll or fold them over). I know that after 4 summers of operating they are actually cooked to the pipe assembly, so I did separate that seal as much as possibe using WD-40 and a screwdriver to wedge in between the rubber and metal, but they are still unmovable. Do you actually have to take off the exhaust elbow to twist it out and then work your way down from there? Thanks for the help.
