Merc 3.0 sounds like it's puffing air
Monty NC
This is a 1996 MerCruiser 3.0 L LX, new to me. It has a rough idle and makes a "puffing" sound, like maybe a cylinder is missing? The video shows how the motor looks and sounds (... and one very unlucky spider):
http://www.smugmug.com/gallery/9138137_M5rFJ
I don't know much about the maintenance history, but I could find out. I do know that it has been run on the water in this condition. I'm hoping a basic tune-up will do the trick... but if it's more serious I don't want to pour money into this.
I have been around outboards most of my life, but his is my first I/O. I now have the service manual (thanks to your adults-only thread), and I am willing to tinker. Where do I need to start?
bigskiohio
Master Chief Petty Officer
Re: Merc 3.0 sounds like it's puffing air
looks like bad exhaust manifold or gasket,loose bolts, i see some water shooting out on the port side back of engine.
JustJason
Good catch on that water leak!!! I wouldn't have seen it unless you said something.
As far as this motor goes... could be a head gasket, bad valve, bad manifold gasket..... Start with a compression test and if your off a cylinder or 2 do a leak down test and find out where your leaking air.
