Merc 140 hp I4, I previously adjusted the lower shift cable and had fwd,neutral,rev on muffs. Took if out this past weekend. First time trying to shift out of forward to neutral no shift ( stayed in forward ). Then as the day went on after shutting down engine then putting in neutral....it would start in neutral. Even on a few occasions I was able to go through gears while running but was extremely difficult to shift. I had to muscle it to get to neutral from forward. I did notice that the idle was way high at about 1400 so I adjusted that and it helped a bit. I checked the kill switch in the rear and it is functioning. I am just wondering if I need to make another adjustment on the lower shift cable or if on the lower unit the mechanism in there is off. I had the lower unit off over the winter and it looked okay but I am not an expert either. Any advice would be helpful.
