zanderman111
Thread starter- Joined
- Mar 15, 2009
- 28
Traded my old boat for an 1987 Sea Ray Seville. Merc 3.0 Alpha one. I know the previous owner tried messing with the timing for whatever reason. Well now its mine and it starts great and I was looking over the engine in neutral at an idle, after about 2 minutes smoke started coming from cylinders 1 and 4 out of the plug! I shut it off and pull the plugs and they are extremely hot!! Tip is white and clearly running too lean/hot right? Cylinders 2 and 3 are fine including the plugs. I took the 2 and 3 plugs and put them in 1 and 4 to see if i was the plugs. Same result, white tip, smoking, and extremely hot, but only on 1 and 4. Is this a timing problem? Or perhaps something with my distributor overloading those two cylinders? What would cause these symptoms? Thanks!
