thompson80
- Jul 8, 2012
- 30
Re: Merc 3.0 carb cost?
Shop that installed the rebuilt 140 sent the carb out to his trusted carb shop for the overhaul/rebuild, so I don't want to doubt that work... yet. I didn't get a chance to talk to him today, will try again in the a.m. I have been using ethanol gas, so just added 10 gallons of ethanol-free marine gas to the 20 gallon tank to top it off. That will be my next test, unless I get other advice. When the engine was rebuilt, the original accessories were all re-used: starter, alternator, distributor, coil, etc. So will check the distributor cap, rotor, (I THINK they're new, as are the points, & condenser) advance mechanism, gap, dwell, and timing when I get a chance. Reading old posts, I read one who recommended advancing the timing 2 degrees, but will see where it's at first before experimenting with that. Another recommended 92-93 octane gas - said that made a difference for him. Since it idles well when warm, and accelerates fine once I get past about 1200-1500 rpm, and runs fine at WOT, I'm not doubting the fuel tank pickup, anti-siphon valve, vent, etc. Will check the fuel pump filter (if it has one? 1980?) - dunno if the shop did that. He did say the filter at the carb was clean when he took the carb off.
Maybe find a new "rebuilder"? On my old 2.5l with 2GC I could throttle it however I wanted and it would respond like it was supposed to. I did the rebuild on the carb myself.
