Merc 260 and 888 outdrive
jrolland
I'm going to be removing the lower unit on my 1975 Sea Ray 190 for the winter so I can replace the impeller and such. However I am not sure where to start.
I was wondering if anyone has a manual for it. The boat was repowered at some point so it used to have a Ford 302 in it and the outdrive model is 888. Also I have no choice but to store the boat outside so do I have to cover up the drive since the lower unit will be removed? Or will it be just fine as is?
Thanks for all your help!
Don S
jrolland
Re: Merc 260 and 888 outdrive
Manuals are easy, you need #4 for your outdrive. Without knowing the year of the 260 (Chevy engine) it's impossible to say what engine manual.
But here they are.
http://forums.iboats.com/showthread.php?t=251571
Yes, you should at least cover the opening where the drive was so water doesn't get in the gimbal bearing. Ziggy just did a post on this.
Have a look.
http://forums.iboats.com/showthread.php?t=283064
Perfect! Thank you so much!
