apocalapsi
Thread starter- Joined
- Jun 29, 2003
- 2
I have a 1986 Black Max 200 Mercury outboard with the following peculiar problem. Upon first trying to start the motor it will crank several times and after releasing the key it will keep cranking even if I pull the key out. The only way to stop it is to pull the positive battery cable off. It finally starts by reconnecting the positive cable, I mean it simply cranks by reconnecting the cable until it starts . After I run the boat it can start and shutoff repeatedly very well and always starts on the first try with no excessive cranking. Does this sound like an ignition switch problem that a new boater can fix or troubleshoot easily? If it is the switch could it be sticking? <br /> As well, as a separate question, given that this boat is an 18 foot Baja, what would be a good general all around use prop? I currently have a 21" aluminum prop that is pretty good for waterskiing but not so good for top speed, and a 25" SS prop that is great for top end but terribly slow to plane. Before I spend a lot of money on a prop that does not suit my needs any suggestions from anyone that would have an idea on what is best? I would love a prop that is allows the boat to plane quickly, and is reasonably good on top end. I thank you in advance for your reply.
