I have a Mercury 20 hp (Merc 20 1979) that was given to me in okay shape, but needed a lot of work. I have it running pretty well, but there’s a couple issues still. When I got the motor I noticed there was a ton of black sticky gunk in the lower pan which I thought was dried oil or grease. Cleaned it out with degreaser. After running it a little I’m noticing more goo on the ignition wires coming down from flywheel and near power pack. I guess I’m looking at pulling the flywheel now to see what condition the ignition components are in. Could this be the stator melting? I realized that someone had put J8C Champion plugs in the motor instead of the L78V surface gaps. Would that cause significant increase in heat upstream in the ignition? I didn’t run it much before realizing those were incorrect plugs, but who knows how long the previous owner ran them. Also I’m getting a faint slightly metallic clicking/ticking sound under the cowling mostly at WOT. I have a video with sound where you can hear it if I can figure out how to upload it on here. Possibly arcing? Motor runs pretty well otherwise for now...
Any thoughts or suggestions?
