bryanwess2000
Thread starter- Joined
- Jul 16, 2008
- 240
I have a V135 and swaped the stock wmh8's for some wmh7's, no changes to anything else. I took it out today and noticed I could only hit about 5200rpm where I was getting 5400 with the wmh8's I was also ~2mph slower. I thought it was maybe due to being on the lower end of the rpm range so I dropped down to 2 less pitch same deal 200rpm less and 2mph less than the stock carb, 5600rpm vs. 5800.
Do I need to cut the heads to take advantage of the bigger carbs or is the tuner different too? I've got a good set of 2 piece heads from a 1985 mariner magnum I can use or I can cut the stock 1 piece heads. I really don't want to pull the tuner from the mariner because I plan to rebuild it later.
