ProjectBoat
- Aug 26, 2006
- 4
S/N: 0G279254 Model#: 1090412RD Uses 3-wire (Black Fill Plug) unit. Have shop manual, all electrical checks out fine but it does not say anything about this condition. In down position, tilt motor runs but will not lift motor. Backed off the manual release valve but still could not lift motor. My "good neighbor friend" then removed the manual release valve which the shop manual says "do not do this". Oh well, sill cannot raise motor. Finally got enough strength (a lot!) together to raise the motor and chock it in the full up position. Not sure where to look from here. Since tilt motor runs I suspect pump/manifold. How can I tell? Is there a rebuild kit for the manifold? Have not removed the Trim/Tilt unit yet.
