Re: Merc 175, air in fuel system
Injected motors have a VST Vapor Separating Tank which has a float operated needle and seat similar to the float bowl of a carb only much larger. Inside this tank is the high pressure electric fuel pump. This pump is switched on/off by the ECU. A pressure regulator is used to maintain pressure at a specific #.
When the key is first turned on the pump should run for 2 - 3 seconds to build pressure, once cranking and running the pump remains on.
Remove the motor cover and listen as you turn the key on, can you hear the pump run?
You can get a high pressure fuel gauge that screws onto the fuel rail and check pressure, if none or lower than spec then the fuel pump may be suspect. Same when unable to reach WOT RPM, check fuel pressure.
Air in the system should bleed out at the VST pretty quickly.
