nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,125
But I won't let it. Replaced my outdrive this weekend while i track down a leak on my last "new" one. Ran it at 4k rpms, no real issues. Noticed it running a little hot--160' v. normal 140'. Seemed worse at lower speeds. When i when to pull it out, the temp bumped to 180'. No problems last weekend with the other drive. When i had it on muffs, i thought i noticed exhaust gas coming from the sea water exhaust near the gimble housing, but it didn't register until later. It also ran hot on muffs--140' before i shut it down. again, usually the temp needle doesn't budge from 120'. i split the case, and the impeller looked rough, but i don't know if it's enough to cause my problems (see pics). Water flowed freely through the upper housing and out the seawater exhaust when i put a hose to it, and i didn't see it come from any place else.
so...
i'm going to replace the impeller anyway, but don't know if i have a separate issue causing this. weird that i didn't have the issue last weekend.
during the offseason i replaced the mani and riser gaskets and the shutter after taking everything apart for inspection. i didn't pressure test, but everything looked to be in good shape. the only thing i can think of is a leak either in the riser or at the gasket--could this cause my problems/symptoms?
guess i'll order a new gasket just in case, and see what happens with the new impeller (good news is that the new outdrive didn't have any water in it after my trip)...
so...
