merc 165 Steering, easy one way, hard the other
jam39vw995
I'm sorry for so many questions.<br />I am gratful so many people don't mind helping.<br /><br />This same darn boat again. I'm gonna call it Russ' Boat. :) So anytime you see a subject of Russ' Boat you'll know. :D <br /><br />Anyway, while under power, it is very easy to steer one direction (can't remember which) but that other way is quite hard.<br /><br />I remember reading about the zinc fin? and if it's off to one side it would cause this? or what would cause this?<br /><br />thanks<br /><br />Jeff
airman
Re: merc 165 Steering, easy one way, hard the other
The zinc fin is also a trim tab. Loosen the allen bolt that holds it and adjust it a few degrees to push the leg in the direction you need help turning the wheel. If it is hard to turn to the right, adjust the trailing edge to the left. When you get it right, the wheel should turn evenly in both directions (at cruising speed) and you should be able to let go and track straight.
airman
It is normal to need a slight angle on the tab. It is caused by the action of the prop.
jam39vw995
Thanks for the replies and answers.<br /><br />Sorry for the waisted bandwidth though. I found the answer doing a search.<br /><br />This forum sure is great. I even read most of the other posts to learn more.<br /><br />Jeff
Jeff,<br />In another of your posts you state the Drive Trim is somewhat inoperatable.....<br />This could Also have alot to do with your handling problems...
jam39vw995
You're right Bondo!<br /><br />DUH! Yes, there is also a trim/hydraulics issue.<br /><br />This boat is such a basket case.<br /><br />Thanks for pointing that out as part of the cause.<br /><br />Jeff
MrBill
jam:<br /><br />The trim tab is not necessary with power steering. It can be left on or off if you have PS, or put in a blank to reduce drag.
