73 Dolphin
- Oct 8, 2008
- 307
I have a 1974 starcraft chieftain 21'6" aluminum center console conversion.
The previous owner swore up and down that it would do 40 mph. As there is no speedo on boat he must have used gps, as do I.
I've completely restored the boat. The original outdrive was toast. I replaced with (presumably) the correct outdrive. 1.65 gear ratio.
Firstly I know that I am overpropped.
I am running a 21 ss prop and max out at 3500rpm. It should be around 4100.
Working on the theory that each 2 inch of prop reduces rpm by around 400 I guess I need an 18" prop.......but........
.......working with prop the calculater, my 21 pitch ss ,3500 rpm with 1.65 ratio and 30mph top speed suggests a prop slip of 28%.
Seems very high ? No ?
To confuse matters if I change slip on calculator to 15% and change ratio to 1.84 I see the exact figures I'm actually getting in real life.
So the question is whether it is more likely
That I have 28% slip or an outdrive rebuilt with wrong ratio ?
Any advice much appreciated !
Weight loaded should be around 2800 lbs.
