shaneburris74
Thread starter- Joined
- Mar 21, 2008
- 11
Every once in a while when pulling up to the dock..jockeying from fwd to rev. the motor will die. Usually starts right back up. When I had it out last weekend twice it was a hard starter twice when shutting down at the dock and attempting to restart shortly thereafter (the motor was warm). It always started up, but one time I had to pull out the throttle arm and give it some throttle while in neutral to get it to kick off. I think this is a problem with the carbs/ fuel. Let me know if you guys agree.
And if so- I am not ready to tear into these carb's right now. I would rather wait till after the season (hopefully I have that choice). The problem is not consistent, 95% of the time it starts and runs great.
Is there anything I can do/ or should do as a temp. fix to clean up the carbs? Any kind of carb cleaner I should use? The seafoam stuff? If I have to tear em' down I will...just would prefer not to right now. Is there a carb rebuild kit out there I can get?
Thanks guys.
Thanks guys.
