Merc 120 2.5 rough at idle and up etc.
trepka2001
was running good then i started having problems with rough running @ idle and cuts out when i try to accelerate. i have to keep pulling back on the throttle to prevent a stall but will eventually get it up to full throttle without any cut out at full. as i back it down it will start to rough idle again, i'm thinking fuel filter or bad gas??
also, don't know if this matters but i have always had a blocked fill vent tube but it has never caused any problems before.
Don S
Re: Merc 120 2.5 rough at idle and up etc.
How long since a full tuneup? Hows the plug wires. Have you done a compression test lately?
Do you have a water seperating fuel filter (you should) any water in the tank, fuel system, or carb?
trepka2001
just bought the boat in July but (i know this doesn't matter) but everything looks in great shape. i was going to replace the fuel filter and put in new plugs, maybe they're fouled but ruled that out because of smooth running at 3/4 to full throttle????
JustJason
nahhh... they still could be fouled. they could be recieving more voltage when the motor is a wot, and not so much at idle.
start with a full tune up. All filters, plugs, points if its got them. If it's the carter fuel pump don't forget about the filter in the pump itself.
trepka2001
thanks for the help!! i'm in the process of a full tune up, want to get it in the water one more time before the water turns to a solid ice block!!!
