Ricktrevi
Thread starter- Joined
- Dec 5, 2011
- 18
2004 merc 115 four stroke engine ..
Could someone tell me how can I remove the engine from the lower unit, or oil pump, Not sure..
I know it has 3 bolts on each side and two more in the front but no matter what I do I can't get it to separate so I can remove the crankshaft cover..
I need to put new inserts cut the crank.. Also change the seals..
Thanks for the help, if I need to post pictures or if you can send me pictures I will appreciated a lot
