Melting flush out plug on '01 Suzuki 115 4-stroke
186logic
I noticed a burned plastic smell on occasion about 10 trips ago. Didn't realize it was the flush out plug until the other day. The motor performs as always, but there is a different sound to it (the exhaust note is a bit raspy). It cranks a while before it starts now sometimes as well, when it never did. I don't think it's overheating since the temp light has not come on as it has in the past. Could it be an exhaust leak?? Fiberglass is burnt a little bit also on the cowl cover in the same area as the plug.
fridays
Re: Melting flush out plug on '01 Suzuki 115 4-stroke
Get it to your dealer !! We have seen a few cases of bad castings that corroded through the exhaust right there. Very odd and premature.
186logic
Thanks Fridays. I'm taking it in tomorrow. I didn't get the 6 yr. warranty(only standard 3) and it's out of warranty now. If it's what you say do you think it will be covered?
