Melted wires/2001 Mercury 60/40 Jet
EB336
Engine has been running fine, however, pulled cowl off to inspect and noticed wiring harness was melted at the connectors. Voltage regulator (black square box) doesn’t appear to be melted or any signs of being hot. Should it be replaced (or anything else) or just repair damaged wire’s? Hard to believe, but engine was running good.04017EEB-9DCD-4E5B-948E-E641AB1CDC00.jpeg
Faztbullet
Common problem with these rec/regulators...test rec/reg and replace if need be and repair wiring.
EB336
Will do. Do you know where I can find procedures to test rec/reg? I don’t have the sevice manual. Thanks!
