Cougar_Bait
Thread starter- Joined
- Apr 1, 2010
- 23
Hey everyone,
I was out boating the other day and had no issues starting the boat. I did a 20 minute stint down the river and as I put the boat into neutral, it died. I tried to start it and was at a loss of power. I went straight to the battery and noticed that the bolt on the positive side of the battery melted out of its casing that holds it in.
I was able to clamp the wire to the positive post and get the boat fired up. The first time it fired over, I had it throttled up a bit because I thought it was flooded. While it was running in a high idle, I backed the throttle control to neutral so I could engage the drive. In doing so, the engine died. I got it started again, had it in a really high idle and quickly moved to neutral and then throttled up high to get moving. The motor sputtered and then kept going and I was moving. I ran it to the dock quick and shut it down.
I got the boat trailered by hand (which sucked with the river current) and got the boat home.
I checked the wing nut and noticed that it was loose. After doing a search here, my thoughts is that the loose connection caused that positive side to get really hot and melt. I have checked all my connections from battery to ground and battery to starter and they are all tight and secure. Now that I think about it, I did not check wires going to and from the alternator.
Is there anything else I should be checking given the positive post melting?
My other question is that I was curious why the motor died when going into neutral. I always thought that once a motor was running, it did not need a battery to run...even at a idle speed. I also noticed that after running the boat for a few, the motor is slow to turn over sounding like a weak battery. Cold starts are no problem, but hot starts suck. So because of those issues, my thinking is that maybe the alternator isn't performing at 100 percent. At higher speeds and idles, the motor can run off of the alternator because it's pumping out what it needs, but at low speeds and low idle the boat is running off the battery.
Sorry for the long post, but I'd rather give more detailed information compared to "My boat died tell me what is wrong". Haha
Thanks,
Mike
Thanks,
Mike
