Mecury Black Max 175, which year?
Ranger118
The plate of the Serial Number was missed.
Here is the casting number on the block. It was located on the port side on the front section of the block assembly
969-9078-C3
Top bearing housing 1159-9642-C
HOUSING, Driveshaft - Black - X-Long (#3503-813563-C)
Anybody know the year of this motor?
Thanks!
Faztbullet
Thats a 2.5 casting...lokk on top of block for quarter sizes data plate with serial # stamped in it.
Ranger118
No Title
Thanks!
I could not find any plate on the block.
BTW, the Lower END CAP Assembly is: 1156-6311
Fun Times
You may have a welch plug with the serial number on it that looks kind of like these for example,
https://www.google.com/search?q=Merc...w=1536&bih=864
attachment.php
Dukedog
there is a build date stamped in tha block. its at tha base of number two cylinder on tha "block half". kinda right behind tha bend of tha advance timing arm. its 1/8" numbers. m/d/yr. might be hard ta see but its there. havin' a hard time postin' pictures. mabe somebody here can do it....
Fun Times
Having a hard time postin' pictures. maybe somebody here can do it....
Thanks Dukedog. One trick I have been doing is, copy the picture you have, make your posts of what you want to say first, then go back and edit your post and paste your pictures. If you paste them before the edit I seem to get the little box where it should be a photo. But pasting them after the original post, it turns out like my post above.;)
I know it's not the best method, but for how things are working around here right now, it seems to be working for me.:)
Ranger118
I checked it carefully more than 3 times, no date number found.
Another clue I found is the Oil Tank. It's number is 99443-3. Hope this helps.
Thanks a lot!
Dukedog
Never seen one without at least an attempt at it but it is MERC. so no surprise!. Last and justa a "maybe". Paint stamp on tha starter? Might still be orginal !!!
