Have a McKee that I got cheap. Transom was rotted. Some advice from a local repair shop said to cut out transom skin as shown. After cleaning, bevel and glass the skin back on. The do sea cure. Some things found:
1. Inside side of plywood has up to 1/4" filler before the inside skin. Thicker on the sides. Filler came out during cleaning. Also some of the filler is cracked.
2. Appears to be no wood stringers. Looks like all foam below floor and on sides. Does anyone know if 1980s McKees had any other wood in the hull?
3. Looking for suggestions for repair method. Other than seacure, is there a way to put plywood back, ie how to tie back to the inside skin and sides?
4. Also noticed what appears to be a blister on the bottom. Is this a deal killer?
Thanks
Thanks
