McKee crafting
xrx1113
I picked up this bare Hull I want to keep it simple with a tiller motor bench in back and a small deck on the front. Can you give me direction for the foam in the floor and the deck
chevymaher
It isn't that hard to do. Do the math on the area under the deck add 15%. Mix and pour the foam in the little holes you make in your new deck. Then clean the mess from the overflow up and seal it up.
