mck
10weston
ineed help i cant get my 9.9 crysler started i have 120 comp in both plugs steeped carb new fuel kit new plugs just sneeses in water what is rong thanks john
bentle
Re: mck
What year is your motor??
Verify your getting good spark on both cylinders.
Is there any chance your flooding the motor out, to much choke?
If you pull the plugs and if they are soaked then dry them off, then reinstall.
Try to start without choking the carb.
You may need to adjust the air fuel mix on the carb. At the start of the forum page there is a sticky which has a link and sink by FrankA.
jkoppe73
Re: mck
FYI, spelling, punctuation and a title that kind of describes your problem will get you a lot more responses......just sayin....
10weston
Re: mck
motor is 1970 9.9 crysler i am not geating gas from carp to plugs just sneezing in water i checked
reeds the lay flat on plate i dont know what to do next thanks john
bentle
Re: mck
No fuel from carb to the plugs? ???
Try to adjust the air fuel mix screw on the carb.
Then you need to make sure the float in the carb bowl is adjusted correctly allowing
fuel into the bowl and closing the needle when full.
Recheck fuel pump diaphragm for for correct fit, and fuel filter if any.
Check for plugged fuel lines from tank to motor and make sure tank is venting.
Are you getting spark to both cylinders? ?
