montejw360
- May 22, 2011
- 88
I replaced the bellows, and now I have a leak. I've pulled the engine (470) in order to do some other work. I trailered the boat into the water to see if I could figure out where the water is coming from. It's puddling in the bottom of the outdrive in the area where the hydraulic lines for the power trim go out. I'm not sure what I might have done when replacing the bellows to cause a leak down there. Unless it's coming from somewhere else and that's just where it's collecting before running into the bilge.
My weekends are very short, working away from home so I don't have much time to work on the boat. I'm posting hoping for some direction for when I do have time. Could it be the exhaust bellow? That one was very tough to install. I'm not sure, but it seems that some marine adhesive would have been better than the "contact cement" sold for installing these things.
Thanks.
Thanks.
