cpt ron jc
- Aug 25, 2010
- 116
Re: Mc-1 lower unit on a alpha one upper unit.
I found part of the problem,the person i bought it from put a new impeller on i took the impeller off and i found a small metal shim on the side of the shaft when i remove it i can get it in and out of gear no problem it turns nice what is it for,as far as the o ring on the shaft i will try again if not i will remove it,i do not have my old lower to compare it to i hope the shaft near the impeller is not longer i was told on the lower it should not matter,i will try it again i am going to a shop knows for sure,thanks much,RC
