maybe another dumb question
Macca1500s
I've just been poking around on my Johnson 90hp 60 degree v4 1999
and at the base of the air box down between the 2 lower carbies I've found 2 grey wires with a white stripe, one has a male connection the other female
can anyone tell me what they are for?? should they be connected to anything, or connected together or are that for an option i don't have??
thanks
macca
Macca1500s
am i doing something wrong, 15 views and no opinions,
can you educate me in how to get an answer??
mabe scream and fly might be a better option!
My wiring diaghram for that motor does not show grey/white wires, sorry. You might trace them back and see where they lead.
F_R
Around here, no response means nobody has a clue. No answer is better than a wrong answer.
gm280
Another idea to get more responses is to post some pictures of your problem. That helps a lot of times... JMHO!
tblshur
my diagram shows grey and grey /yellow has to do with tack does tack work ? hope this helps.:)
Macca1500s
yep tacho works, everything seems to work.
I've been chasing a hard to cold start issue, however today i have cut off the cable ties the mechanic used to attach the primer bulb and have fitted screw type hose clamps, suddenly when priming the bulb it now does get hard so hopefully that may have been a problem, even running maybe it was sucking some air.
however while checking out the primer/choke solenoid i discovered these two wires, and hoped i had not knocked them off from somewhere..
Earlier when mucking around i knocked off a breather, a small hose running from high up between the two top carbies that runs to the air box.
so I've set a pattern
im stressing as i have not had an outboard for a very long time and am concerned about the whole thing.
like leaning out cylinders and all sorts of stuff, probably doing to much reading and not enough out on the water
i had intended to take it out today but my daughter decided to have a baby, darn kids so thoughtless, hahahah
guess I'm going to have to go now and do the pop thing for a while
Roberthill
Only wires I found with a white stripe on it was a blue and a green wire which is trim up and down and they do have a male and female connection . Sometimes these wires fade and it's hard to recognize original color but if your motor trims up and down ,it's not one of these .JMT
Macca1500s
ok so its been a couple of days, and every time i check the primer bulb it only takes a couple of squeezes to get hard ( don't even go there)
whereas previously you could squeeze for ever and it never really got hard.
i think I've been lucky, could easily have been sucking air, and from researching, that could have been catastrophic.
stupid professional mechanics, you put your self in there hands assuming they know, and thats what happens, cable ties instead of hose clamps, yep it sure did look pretty on the transom though
and i guess from the mechanics point of view, i would never know why the motor blew up.
and he would have gladly pocketed my money.
just as well its been winter here and i haven't used it much
early next week i get the chance to give it a run, heres hoping all is good.
Macca1500s
just posted the above and thought hell i should try it ( i try not to start it to often out of respect for the neighbours, noise and smoke)
anyway primed the bulb, hit the key, pressed the key in and bang it started right up, whereas previously i would crank and crank it, eventually spraying some wd40 into a cylinder to get it to start.
i think whats happened is that the cable ties when first put on sealed it but as the hose relaxed/softened/or took a set then the cable tie was no longer tight enough,
what made me wonder is that i had just started to notice a fuel/oil mess starting to appear on the swim stet part of the transom.
fingers crossed
Macca1500s
wooo hoooo took the boat out today and it went well screamed eeeeehahh
ok ill calm down now, only thing I'm doubtful of is that at 6 knots through the marina it seemed grumpy like it was occasionally missing on a cylinder,
but as soon as i got out to the open bay and accelerated it just took off, I'm so happy, i have to adjust the trim limiter, because when i nail it the steering loads up so badly i can barely control it.
ran into a mechanic when we got back and he recommended adjusting the trim down position limiter shaft to a higher position he also said r/e the rough idle at no wake speed that i should trim it up a bit and see how that goes (????) ill give it a go , he said that trimming it up a bit would lean it out a bit and could help, he seemed to indicate that the rough idle was due to the cylinders loading up. the no wake zone i have to run trough takes a good 10 minutes so i don't know maybe??
oh and heaps less smoke
as I've said before i know very little about outboards and especially 2 strokes, I've always considered them a black art
most of my boating life its been EFI sterndrives with power steering.
but I'm willing to learn, so all helpfully comments are greatly appreciated
thanks for reading
