May day!!!
Blue Lew
My 03 115 Merc still runs bad after the injectors were cleaned, can any one help me??? Used Seafoam to clean the fuel lines.
latin monkey
Re: May day!!!
you need to give more background info on how it was running before you had them cleaned and how you cleaned them
jhcreech
Re: May day!!!
start with the basics, fresh fuel w/no water, spark plugs good, all cylinders firing, good flowof gas to the injectors, is the compression good and even on all cylinders, all grounds/positive connections good and tight free of corrosion, dont know what kind of fuel tank u have but make sure it is well vented.. hope this helps..:)
