Re: Maxum Boat help and info needed please!!
Welcome to the boating world! I to have a maxum but mine is a foot lager than yours with a force 150 on it, you will be pleased for many years with it. but some stuff you should know but not to scare you cause i have had to learn the hard way. like several other people on here. but for starts the small tears in your cushions can be repaired and or recovered, just call around and ask to see who does it. just make sure its marine grade stuff. but the boat it self will bive you no problems. the force engine will if you dont take proper care of it. the #1 thing i would do. and its not hard @ all its to replace the impeller. its a cheep part and should be done everyother season. Esp. replace it if you have no idea when it was done last. Force engines will not tolerate being over heated @ all. #2 also a cheep mantinence item is to change the lower unit oil. mine wasnt done in 10 years. (just because i didnt know) #3replace the spark plugs. i know this sounds like alot, but, doing the small stuff now will keep you in the water alot longer. and dont forget to winterize it this winter. Force engines are cake to winterize. good luck
