...As for the exhaust, I blocked the one the water was coming out and tried running the engine, water did start coming out the other side, when I removed the tape from the right side all the water came out that side, am I correct in thinking that with an inline 4 there is only one exhaust and it just splits into two exit ports, and that it wouldn't matter which side the water came out?
it's great to find out more about the engine.
Once again cheers.
Paul
Finally!!!... Only took 16 posts :facepalm:
Sounds like there is water in the U joint bellows, possibly the shift shaft seals. or missing o- ring on the drive pull right away. Since its off check alignment and check/grease gimbal bearing and check u-jointsHi Guys, well i am going to take off the stern dive and change the bellows tomorrow, so thank you for all your advice, i tested the boat again last week and found a small amount of water dripping off the gear cable at the top of the engine, it left salt deposits as it dripped on the right hand side of the engine by the dip stick, any ideas how this is getting in?
It seams strange as the water would have to work its way up the cable in order to drip, it has me puzzled.
Thanks for any advice.
Well I have found the leak, it was a hole in the shift bellow!
Bit more advice please,
1. What is the best way to get the new shift bellow on? And how to feed it back in?
2. I am going to replace the oil line, what is it for and best way to fill it with no air locks?
3. What is the best way to attach the exhaust and uj bellows when putting it back together, looks tricky?
4. Any other top tips or checks
Cheers
