Re: Maximum spark advance screw 93 Merc 15hp
I'm assuming from your title that you mean the max. spark advance stop screw.....
It prevents the motor from getting too much advance on the spark. Too much advance and the fuel charge will burn too quickly and have time to build up enough heat to melt the piston top (detonation). If you've adjusted it, or don't think it's right, get a manual and set it correctly or you will ruin the motor. They rarely if ever need adjustment. If you have a basic timing light, they're not hard to get set back correctly.
Hope this helps,
JBJ
