Re: Maximum Spark Advance Question?
No, the motor needs to be under load or you risk blowing it up. The manual means that you shouldn't run your motor at high revs on the muffs with no load on the motor.
The idea if you want to set your timing with the boat on the trailer is to back the trailer down the ramp far enough to put the prop & water intake underwater. Then you run the motor in gear up to full revs. Sounds scary I know but you can do it (the boat should be tied down well). The alternative is for you to hang off the back of the boat with someone else driving it a full speed. Also scary but you can do this too.
With the OIS ignition system you can set the timing without running the motor using an electronic analyzer. These are expensive to buy (like $300) but I have designed a simple circuit to do this and I can supply details if you want to build one. A few of the iBoats members have built them. Takes basic electronics skills and about $20 worth of parts. Email me at
Seasport1@hotmail.com if you are interested.
