Max timing advance topic L6's
monk-monk
I adhere to the max timing advance for my '72 1150, but i don't understand some things: Why does it melt the pistons? My first thought is that it must be lean on fuel to burn a piston. I understand piston displacement and the ratio of the event cycle (intake or exhaust) does it run into an overlap on these cycles that it is firing when there is still burned fuel in the cumbustion chamber?
j_martin
Re: Max timing advance topic L6's
Temperature too high will melt a piston. That can be had in several ways.
1. Lean burn. In a 2 cycle engine, excess fuel is used to slow down and cool the combustion process. Modern DFI engines go at this the other way, by delivering sparse fuel directly into the combustion chamber and timing it down the stroke to provide a smooth, relatively cool burn.
2. Cooling failure.. Self explanatory
3. Pre-ignition. If the fuel charge is ignited while it is still being compressed, and the cylinder pressures get too high, temperatures also get too high. When you increase the pressure on a gas, it is heated. That's what makes a diesel ignite the fuel, and why you can burn your hand on an air compressor. Normally things are flying around pretty fast, so it's normal to light the fire considerably BTDC so it is going when the expanding gases are needed ATDC. If you get carried away, the pressures get too high.
hope it helps
John
monk-monk
Understood!! Very well explained...I cannot believe the education i get on iboats! Education is expensive...EXCEPT on iboats, where you get it for free from some of the nicest people!
achris
More fish than mountain goat
It's a really steep learning curve here... :D:D:D
monk-monk
So, im really trying to figure something out here. I want to know why when i get my motor to about 4200 rpms...and i still have more throttle to give it, but when i do...it will kinda bog the motor down and will spit gas back through the carbs, especially the center and lower carbs. NO, its not the reeds...i know they are new factory replacements.
