Re: MAX RPM'S ON A 1992 5.OL OMC/COBRA OUT DRIVE
LOSE THAT 21 pitch!!!!<br /><br />You are running a 5.0 is it carb or Injected ?<br />you have a little more power on a injected.....<br /><br />Now OMC cobras are good drives , they have coffee spilling Hole shots on a 17 pitch , the have the best performace of both hole/top end on a 19 pitch<br />and crappy hole shots and more crusing above plane with a 21 pitch.....<br /><br />NOW check this out you boat is made to run at about 4200-4600 WOT rpm you are OFF(running lower)by between 600-800 rpm. That is alot my friend.<br /><br />You may ask.... why is that bad?<br /><br />Well to answer that, you are kind of okay....<br /><br />BUT listen to this, WOT throttle is design'd to give the boat the MOST HP(ponys) through out the entire RPM as well as at the TOP. Not only that but very harmful carbon build-up starts to slowly take place, when the engine is not able to meet its WOT. This will lead to "lug" on the engine,higher running temps, and detinaiton.<br />Which harm engine performace....<br /><br />So you could say your boat isnt running to its<br />-" full "-<br /><br />I would Go to a 19 for best cobra performace ALL around. (hole/load/top)<br /><br />But you can spend some $$$ and deck out the engine<br />(I would) I tell you your boat will love you for it But at this point your 21 is lug'n that boat...<br /><br />think if it was full of peeps , tow'n somthing<br />it has to struggle to get up to plane right?<br /><br />By the way are you alum or stain prop ?
