max rpm
zenchal26
what should be the max rpm for a 1988 70hp evinrude
ezeke
Re: max rpm
I think 5500 - 5800 would be ok target for the top end on a crossflow, but this motor is a looper and you might want to go say 6000 to 6200. It isn't about fuel quality, it's about lugging the engine.
ezeke
Re: max rpm
See if you can raise DHadley. He can give you a more definitive answer. There is a point where you start to lose your advantage. I've been taught to peak at 200 RPM above the specifications range.
