Sounds good, have any thoughts on setup pistons, deck height, gasket?
most machine shops will cut the deck to true it up to the crank center. they will also line-hone the crank bearing bores. this will put the deck between .005 and .010
many pistons are available with a .010 combustion height increase to forego zero-decking. with that combination, .041 head gasket.
the KB +12cc D-dish or the ICON (economy KB) +12cc D-dish
FWIW.......haven't even pulled the engine yet.
Wanna get this worked out before I even go to the machine shop and he starts suggesting things.
I would like to know what I'm looking for before that.
So far considering a Comp Cam XM270HR, deck the block to 0.015 and find a 0.025 head gasket (not sure of the numbers, want a 0.040 quench), and find matching pistons.
Tony, talk to your machine shop before buying parts. infact, have your block sonic tested and hot-tanked prior. I know too many people that bought parts....found out block was junk... sent parts back and bought different parts.
if it was me, I would get a scat/kb stroker rotating kit from someone like competition products. call them, they will package a kit (most of what they do is NOT on the webpage). and they are less money than Summit
http://www.competitionproducts.com/Engine-Kits-and-Rotating-Assemblies/departments/198/
also, keep an eye out in Craigslist for someone's project motor. co-worker just picked up a 509BBC that is fresh from a machine shop from a guy going thru a divorce. he paid $800 for $3500 worth of motor because the guy needed rent money for the apartment he needed to get.
what ever you do, get the rotating assembly balanced
